Results 1 to 7 of 7
Thread: 4t65hd histogram help.
    Oct 2020
    10
    Post 4t65hd histogram help.
    Long time listener, First time caller so please correct me if i am posting in the wrong section.
    2008 grand prix gxp 5.3 4t65hd. just purchased the car from the family of the owner of this one owner high mile car. runs drives good. sometimes at highway speed if i tip in to appx 25-35 percent throttle the converter will shuffle. I have already changed the tcc apply to 99 percent max and 55 min. Anything much over 55 min will cause harsh apply. I want to turn the pressure up in the trans with the pcs motor. I need help setting up a histo to see the effects of lowering the pcs motor voltage. I am assuming i want to log line pressure of the trans? I have played with several histograms and am unable to get it to populate data.
    thanks in advance
    Nov 2017
    1,466
    I watch a lot of Scanner Danner videos and he was making fun if "instant shudder fix" until he actually tried it. How is that stuff long term or is it more of a short term fix?
    7,648
    How many $3 tubes of goo would it take before it became cheaper to replace the converter? I mean, neither tune changes nor the magic goo are going to really permanently fix anything.
    Aug 2023
    SoCal
    452
    Do not raise pressure and TCC apply rate on that one, it is already too high from factory for what the converter can handle. What you have here is the usual issue behind those 5.3L where the lock-up piston got deformed and touched the cover. The more you drive it, the more it will load the unit with metal shavings which is like liquid sandpaper that will damage a bunch of hard parts. You need a new converter that is built with a billet lock-up piston. I don't think anyone rebuild those with OE piston anyway because they are always trash. They can handle only 120 PSI max and on those after a few years where you have crossleaks the pressure often goes up to 140 bending it past the point of no return and it is all over. They make a relief for it to prevent the pressure from going above 120, but it is a bit hit and miss. Much better to just get a converter with a piston that can handle it.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Oct 2020
    10
    Robert price me a converter with a little more stall. I have a wholesale acct with you. Drop me a email. [email protected]
    QUOTE=TransGo Robert;747295]Do not raise pressure and TCC apply rate on that one, it is already too high from factory for what the converter can handle. What you have here is the usual issue behind those 5.3L where the lock-up piston got deformed and touched the cover. The more you drive it, the more it will load the unit with metal shavings which is like liquid sandpaper that will damage a bunch of hard parts. You need a new converter that is built with a billet lock-up piston. I don't think anyone rebuild those with OE piston anyway because they are always trash. They can handle only 120 PSI max and on those after a few years where you have crossleaks the pressure often goes up to 140 bending it past the point of no return and it is all over. They make a relief for it to prevent the pressure from going above 120, but it is a bit hit and miss. Much better to just get a converter with a piston that can handle it.[/QUOTE]
    Aug 2023
    SoCal
    452
    Quote Originally Posted by Ryanc5413 View Post
    [/QUOTE]
    We do not rebuild converters here, you must have me mistaken for someone else.
    Robert Moreau
    TransGo
