Results 1 to 4 of 4
Thread: have drive mode reset to normal when ignition is cycled
    Apr 2023
    19
    is it possible have the drive mode reset to normal when the ignition/key cycles. What I'm find is that if I engage tow/haul it stays active after the ignition has cycled off and back on.
    I'm using a 2022 7.3 Godzilla with the 6R140 swapped into a '78 F250.
    An indicator would also be nice - does anybody know if there PCM pin that energizes the tow/haul light?
    Oct 2016
    Poland
    1,583
    no, this is send via can bus to the cluster
    Apr 2023
    19
    thanks veeefour.
    I also figured out the drive mode reset was not happening because I was using a latching instead of momentary switch. With the momentary switch, it resets to base/normal when key is cycled.
    Oct 2016
    Poland
    1,583
    Quote Originally Posted by Ford385 View Post
    thanks veeefour.
    Looking at the schematics this might be case, schematic calls for momentary.
