tune attached 02 sensor just goes 447 to 451 volt only
learning
Having voltage at ~450mv is not a tuning problem.
what would cause problem, truck running rich LTFT not working
learning
Voltage at 450mv basically means open circuits. You have wiring issues to the sensors.
Should be using a wideband to dial in the fueling too, way better than using narrowband sensors.
thanks i am using wideband ,that what i noticed first
learning
