Results 1 to 5 of 5
Thread: MPPVI3 Prolink cable pin out
    Can someone check their Prolink cable and the pinout is where it plugs into the MPVI3? Really just need AD 1, AD 2 and ground
    1 top left
    2 top right
    3 bottom left
    4 bottom right
    5 outer ring
    Does anyone have a prolink cable that they could Ohm out the red and blue wires to see which pin they touch?
    Mar 2023
    23
    It blows my mind this does not come with any info....trying to figure out how it gets wired in also.
    Wasting time sifting through a damn forum instead of making progress on tuning the car.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    You can find the pro link wiring information here
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    466
    To answer the original question; there is no direct connection between each end of the ProLink cable.
    There is circuitry in the cable, which is converting the inputs in to a data stream for the MPVI3.
    Because of this, you can not simply send a 0-5v signal in to the MPVI3. If you need analog inputs, you NEED the ProLink cable.
