Results 1 to 9 of 9
Thread: Unable to complete download VCM Suite Beta when using the scanner or tuner
    May 2003
    South FL
    1,376
    Usually I always use the about button in the program to download new beta updates to my beta versions. But the last two I keep getting the error that I cannot complete the download. If I login to my HPTuners account in the web portal and download the beta and install it, it does install and works fine.
    Is this something that is a local issue to me or is this a current known issue with the Beta Versions?
    [email protected]
    Owner/GM Calibrator
    28,275
    are you able to post a screenshot of the error message you are seeing?
    May 2003
    South FL
    1,376
    No matter what I do it always stops and says that the download cannot complete. This has been the case for the past 3 beta revisions. HPTuners itself does not give an error. I never had this issue until the last 3 Beta's.
    [email protected]
    Owner/GM Calibrator
    28,275
    what browser are you using?
    May 2003
    South FL
    1,376
    Chrome
    [email protected]
    Owner/GM Calibrator
    28,275
    I would suggest you try switching to a different default browser. I just tested using Chrome(116.0.5845.188) as my default browser and was unable to recreate the issue through either editor or scanner beta
    28,275
    I would suggest that you open a support ticket in this case, at least that way it goes to our web admin for further troubleshooting.
    May 2003
    South FL
    1,376
    This issue seems to be corrected in the last Beta release, I changed nothing on my local machine. I had to manually update from the website a couple of beta versions and then it started working. Not sure if it was the version or an actually host server issue but I wanted to report the issue is fixed as of yesterday.
    [email protected]
    Owner/GM Calibrator
    7,729
    Just happens sometimes. There was a stable release version a while back, like 4.something, that would check for updates and not find one, even though there was a newer version on the download page.
