Power Enrich Fuel Adder vs. RPM vs. Time: This table adds to the base AFR in relation to RPM and time in PE mode. It is used to provide additional RPM and time based enrichment and is similar to the PE vs RPM table on V8 engines, but with an additional time component. Remember, this value adds to the Base PE AFR so positive numbers here are leaner and negative numbers are richer.
Is there any way to set up a histogram in the scanner for this table?
I either cant figure it out or its just not supported yet.
