Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: seadoo gtx 170hp
    Aug 2022
    EU
    8
    seadoo gtx 170hp
    Hi all, i look for US ori file for seadoo gtx 170hp, many Thank's.
    Jan 2022
    Galloway NJ
    148
    Quote Originally Posted by kfranc View Post
    you'll get the stock file when you connect your MPVI to the ski and download the stock tune.
    Aug 2022
    EU
    8
    Quote Originally Posted by Tbranella View Post
    can't read file, error retrieve ..., work on RXP300
    Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    190
    i dont think is available, what year 170 ?
    Mar 2022
    25
    here is a full bin file for you to reference for 170 1500cc seadoo.
    beware if this is NOT your oem file as immo key will prevent starting.
    its modded by myself for limits rpm and vmax and it is NOT stock. this is what you're looking for
    SEADOO mod GTX170 Vmax off RPM 9200 9 23.bin
    Aug 2022
    EU
    8
    Quote Originally Posted by RUTHLESS View Post
    2022
    Aug 2022
    EU
    8
    Quote Originally Posted by VFORCEJOHN View Post
    thank's, i will test it
    Sep 2022
    WorldWide
    190
    thank you i will send to the engineers
    Sep 2022
    WorldWide
    190
    do you happen to have a stock file ?
    Aug 2022
    EU
    8
    i have two files EU old SW and update
    Seadoo GTX 170 (Original) - 066838.binSeadoo GTX 170 (Original) - 082138.bin
    Sep 2022
    WorldWide
    190
    thanks ill send this to hptuners
    Sep 2023
    19
    Is that the oem file for a 2022 sea doo gti 170?
    Wondering if I can load that in my 2023 gti 130...
    Jan 2022
    Galloway NJ
    148
    Quote Originally Posted by Swampdonkey View Post
    to make your 130 into a 170 all you need to do is change the model number in BUDS.
    Mar 2022
    25
    The 130hp version is simply throttle, air table trim, lambda target and timing advance is more restricted. Looks to be similar limiters as the 170. Changing the cal file in buds rewrites the whole entire Calibration file PLUS the EEPROM regardless of what it appears to do. Wrong OS to wrong EEPROM OS and it?ll never start or the checksum will not permit use of the immo. It?s Quite in-depth as it?s ALL changed.
    If anyone tests out the Seadoo 170 limits. Let me know if it works. There are a few other methods of data organization to accomplish this as well. I modded that in about 5 mins for JUST those limits. it?s just speed which are FF?d off, rpm limits and extended axis values for the usable maps. unless more limit parameters show up.
    Aug 2022
    EU
    8
    i have test your file, now take 8200rpm max, with more timing 8100max but take 8800 at midle load, the best for the moment is more timing at midle load and oem hight rpm.
    Jan 2022
    Galloway NJ
    148
    you're not changing the cal file in BUDS..
    you're just changing the model number of the ski.. this is the same thing as changing the model number of a US spec 300 to a european spec RS model for raising the GPS limiter.
    this has already been done MANY times and it works perfectly.
    when the ECM sees that model number, it automatically knows it's a 170.
    Jan 2022
    Galloway NJ
    148
    I wouldn't go adding timing without logging AFR.
    Aug 2022
    EU
    8
    i logging with AFR and data stream added
    Mar 2022
    25
    Was the file capable of more rpm and speed?
    Aug 2022
    EU
    8
    i have increase many ecu limit, now 100km/h
