Results 1 to 3 of 3
Thread: "Fuel trims" question....using WB
    Feb 2006
    Canada
    1,958
    When the NB has been replaced with the WB in a V6 forcing OL, why would we reset fuel trims? Looks like all trims are dissabled because of OL.
    Have been hitting the reset of fuel trims but wondering if this step is really necessary?
    Thanks for lookin' guys!
    Paul
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    It's just a good practice to check the fuel trims after a write. After the first write if the O2S1 was removed, and the fuel trims reset, the LTFT's will stay at 0 the next time you write to the pcm. This is because the pcm's fuel trims are not erased after a write.
    Russ Kemp
    Feb 2006
    Canada
    1,958
    Thanks Russ. By the way, your write up on tuning this model V6(3400) is amazing. Has worked like a charm bud! Thanks again...now for my issue with timing.hahhahahaaah
