Hi everybody!!
I have a 2002 Silverado, 5.3T, 4L60E 4wd. I just upgraded to a 130amp alternator and added electric fans. Flashed the new settings to the ECM and couldn't figure why it wasn't responding properly, with the fans running as they should. I just manually turned on the fans and realized they are pushing instead of pulling. Does anybody know if there is a way to reverse them or are they generally one direction only? Dual fans for a 2006 Sierra, 34" radiator, aftermarket wire harness using triple relays, dual fuses, white to C1-42, Green to C2-33(removed existing recirc wire).
