Results 1 to 18 of 18
Thread: Hummer 2004 2 bar OS calibrate
    Apr 2007
    Novosibirsk, Russia
    37
    Hi, all
    I was checked os 2 bar patch for Hummer h2 2004 6.0 v8 calibration map sensor.
    It has 200/10.33 values at soft after patched rom.
    But, its not correct, on idle map 2 bar (at VCM scanner) show around 105kpa, but non elrctic external map sensor show -0.4 bar, 60kpa so really.
    Can any help with true values for map liner and offset, please?
    Thank you
    Alex
    Aug 2006
    5BA8
    3,253
    Need to know what map sensor is in it. There should be a part number on it. Photo would be best if you can do that.
    EFI specialist
    email=[email protected]
    Apr 2007
    Novosibirsk, Russia
    37
    thank you for reply.
    It's important, are there not recalibrate?
    I can say, liitle late.
    It's stock map sensor for hummer h2 2004, oem values 94,43/10,33 are correct by VCM logger shows.
    Thank you
    Alex
    Aug 2006
    5BA8
    3,253
    Quote Originally Posted by sss7556 View Post
    Thank you
    Alex
    I hope this comes out correctly using your translator. There is no point in using a 2 bar custom operating system with a 1 bar map sensor.
    You need this part number 19418810 AC Delco.
    EFI specialist
    Apr 2007
    Novosibirsk, Russia
    37
    you mean, I can not recalibrate 1 map oem sensop for 2 bar range? only replace it?
    Jan 2014
    SoCal
    1,565
    Map sensors are not internally calibrate-able. They have a specification based upon a relationship of pressure and voltage.
    Long story short.
    If you have a 1 bar OS you need a 1 bar MAP.
    If you have a 2 bar OS you need a 2 bar MAP.
    If you have a 3 bar OS you need a 3 bar MAP.
    Nov 2006
    2,742
    Beyond that.. remember you need to delete the original map sensor pid and add the custom OS 2 or 3 bar Map sensor pid.
    The original pid will work but only read up to 105kpa
    Tuner at PCMofnc.com
    Apr 2007
    Novosibirsk, Russia
    37
    of course, checked by 2 bar sensor
    Apr 2007
    Novosibirsk, Russia
    37
    see pics for oem map sensor
    Apr 2007
    Novosibirsk, Russia
    37
    so that 19418810 AC Delco will fit replace oem map?
    see oem pics, please
    Thank you
    Aug 2006
    5BA8
    3,253
    Thank you
    Correct. That part number is "plug and play". Connector is the same. Plugs right into the same hole, same size. Put your linear and offset back to what it was in the initial COS and you're good to go.
    EFI specialist
    Nov 2006
    2,742
    Should be 200 x 8. won't make a huge difference but technically correct.
    Apr 2007
    Novosibirsk, Russia
    37
    ok, million thanks!!!
    Apr 2007
    Novosibirsk, Russia
    37
    check it, thank you!
    Aug 2006
    5BA8
    3,253
    Yeah that falls under "close enough" LOL
    EFI specialist
    Apr 2007
    Novosibirsk, Russia
    37
    hi
    you mean, delete at vcm scanner for logging?
    Mar 2022
    Indiana
    2,944
    hi
    Yes.
    Apr 2007
    Novosibirsk, Russia
    37
    Yes.
    of course, tks
