Hello,
Hoping to find some ideas for an issue I am having with my Z06. I've included a data log, current tune, and modification list.
If outside temps are higher (70+) and I'm really getting into the car it's a matter of time before it starts to act up like it has a massive air leak, the car has been smoked multiple times for leaks. It's hard to replicate given unknown parameters besides it just being hot. The long-term fuel trim goes crazy when this happens as the car appears to be going lean. It happens almost like the flick of a switch, cars working fine and then suddenly it's not.
The issue seems to present itself after a few hours of driving. It's happened twice now:
First time during road tuning at highway speed going up a 2-4% grade under acceleration. Was able to do this around 7-10 times before the car acted up, bucking under acceleration acting as if fuel starvation was present. Had to sit at a gas station to cool down and limp home.
The second time this has happened, the logs attached was this past week during an Autocross event. Temps around 65-75 I did multiple runs and let the car cool when needed. Again, it just decided to enter a lean scenario and add tons of fuel. I had to end my autocross day, let the car cool for around 2 hours, and then drive it home. During the drive home, it appeared to act normally again but out of caution, I did not really "get on" the car.
- Compression test August 23: 140psi on all cylinders
- Leak down test August 23: Resulted in no leak down on any cylinder.
- OEM AC Delco spark plugs installed August 23: Gapped to .40
- OEM AC Delco spark wires were installed on August 23 as well
- Brand new OEM coil packs were installed in August, we also tested each coil/wire to ensure pulse and voltage were all even and working correctly with injectors, wires, and coils. I don't recall the computer setup used but it was alot of wires hooked up to the car!
