The EGR code is still in the PCM. I have it Enabled in my 2005 P59 running a L31 350 based engine for the same reason to log data using the 0-5V input. In my case it is fuel pressure I am logging. The factory 2005 350 setup had it disabled and factory EGR block off plates/caps on the intake manifold and exhaust manifold. Some of the 4.3Ls running on P59s had EGR until much later, probably CA spec. Express vans had EGR with the P59 through 2003 on the 2500 and 3500s with 4.8s and 6.0s too.
