Results 1 to 2 of 2
Thread: 2010 chalanger 6.1 time retard issues after cam install
    May 2021
    7
    Exclamation 2010 chalanger 6.1 time retard issues after cam install
    2010 Dodge challenger srt8 6.1 cam install, long tube headers,high flow cats. I encounter knock under WOT.
    main issue is knock retard
    cam specs:
    intake;
    Lift: 340
    valve lift: 561
    duration : .50" 218
    Exhaust:
    Lift: 340
    valve lift: 561
    duration : .50" 226
    1st time tuning a dodge but im pretty familiar with standalones and gm vehicles.
    I removed timing for WOT tuning at 1st pull I noticed knock pulling -.05 -1 retard timing
    Proceded to check AFR's / lambda on point and still
    retarded timing from 17 to 15 now to 11 and still.
    added 35% lf knock sensor Voltage
    checked limits
    here is the last log and calibration.
    Thank you in advance.
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    Quote Originally Posted by alsdriftshop View Post
    Welcome to backwoods country of Mopar Tuning.
    Bring Fueling in earlier that'll help .
    Whats the end use of this Charger Daily/Racer , Racer/I drive it to the track ? or Yeap I have a charger with cam , why is it slow as balls?
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
