Results 1 to 15 of 15
Thread: RTD+ won?t write
    Oct 2023
    8
    RTD+ won?t write
    Hey everyone when I had my magnuson installed they gave me an RTD+ OBD2 Bluetooth module to change between tunes. It has worked flawlessly up until today. I tried to write a specific tune for octane to the car this afternoon and after connecting the RtD+ and the phone on the Bluetooth I go to write to the car and it blinks green 4 times and than either freezes or the light disappears altogether. I?ve done all of the basic troubleshooting, even went as far as to unplug the car battery to reset everything. Any help would be appreciated.
    Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    186
    Quote Originally Posted by Clg View Post
    Does it start. Do you have another odb tool. Might be toast but check fuses could as usual be anything, not enough info to go on. Sounds like if it started to write and stopped thats clearly a fail. Might be able to write over with hptuners just depends.
    https://ls1tech.com/forums/pcm-diagn...-read-ecm.html
    I know you dont have hptuners but I would check the power to the ecm and look everything over
    Oct 2023
    8
    Car starts just fine, it seems to just quit writing after it connects…..really odd…..my Banks iDash OBD2 gauge works just fine, so it seems to be an issue with the RTD+. If I purchase a new one can i just hook it in and have the app “TDN” that i use write to the car?
    Oct 2023
    8
    Quick question, if I purchase another RTD+ module can i just write from the TDN app to the new one without any issues?
    Oct 2023
    8
    Anyone? lol
    Aug 2023
    Corpus Christi, TX
    186
    Your using your phone to bluetooth it over?
    Nov 2017
    1,533
    Anyone? lol
    Not a lot of RTD use on the forum so you might have to direct this at HPT support.
    Oct 2023
    8
    Quote Originally Posted by Guy With A Chevy View Post
    Correct, it even pairs just fine.
    Oct 2023
    8
    I noticed HPTuners support on here a lot, was hoping they would stumble on this thread since they don't accept PMs for some reason.
    Aug 2023
    Corpus Christi, TX
    186
    I figured you had already considered contacting support and figured this avenue would give some info. Atleast it didnt brick your ecm. Just maybe it could be a pairing issue try reinstalling the app and forgetting the bluetooth connection.
    Aug 2023
    Corpus Christi, TX
    186
    You leave it plugged in all the time?
    Nov 2017
    1,533
    Did you put in a support ticket? Not much drive by from support on the older GM forums.
    Oct 2023
    8
    I unpaired the bluetooth deleted and reinstalled the app....unplugged the car battery....it seems like the bluetooth functionality isn't the issue, it's when it wants to write to the vehicle itself that is the issue....
    Oct 2023
    8
    I did, any idea how long it usually takes them to respond?
    Aug 2018
    294
    Have you done a "re-sync interface" in the software? Sometimes that fixes silly issues with MPVI's. Might work for the RTD's too
