Results 1 to 15 of 15
Thread: Stock Tune ? Sea Doo 325 / 2024
    Oct 2023
    Does anyone have a Stock Tune ? Sea Doo 325 / 2024
    they can post up?
    Thank you
    Gian
    Jan 2022
    Galloway NJ
    116
    Quote Originally Posted by Gian View Post
    they can post up?
    Thank you
    Gian
    not until the ECU is cracked..
    Mar 2019
    11
    Quote Originally Posted by Tbranella View Post
    Not true
    Jan 2022
    Galloway NJ
    116
    Quote Originally Posted by RaraK69 View Post
    Not true
    NICE!!!!! now make an HP Tuners stock tune file from it. ( i'd LOVE a copy of that)
    Mar 2019
    11
    Yea theres some other work first with disassembly to verify some things, just working through things on spare time as this is just fun for me with free time.
    Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    150
    they can post up?
    Thank you
    Gian
    Send ecu to hptuners and they would send you stock files ones is read
    Sep 2022
    WorldWide
    150
    ummm ok
    Jan 2022
    Galloway NJ
    116
    any progress on this??
    Mar 2019
    11
    At the point I need ecu in hand and on my bench setup. So may order one soon.
    Jan 2022
    Galloway NJ
    116
    how did you do a HEX dump post a pic of it if you didn't have the ECU in hand?
    Mar 2019
    11
    Manufacturer flash files.
    Jan 2022
    Galloway NJ
    116
    ahh.. ok, that makes sense.
    the ECU is only $559.00 MSRP
    Having the firmware doesn't mean much, the issue is the ECU uses very very high level of encryption so you can't write it. There's zero chance the encryption itself will get cracked. The only possible workaround is physical modification to the ECU to replace component. Even if you get the ECU modified it's not like you'll be able to fire up HP Tuners and start tuning the ECU. Flashing these modified ECUs will probably, for the time being, be limited to those doing the actual hardware modification.
    Jan 2022
    Galloway NJ
    116
    Quote Originally Posted by racemonkey View Post
    yes, but I'm just curious to see what the stock tune looks like.
    the ECU will be cracked eventually... it's just a matter of time.
    Sep 2022
    WorldWide
    150
    i have the 2024 rxp325 stock file but the issue now is editing protocol and writing it
