Results 1 to 6 of 6
Thread: pcm vss problem
    Oct 2023
    3
    pcm vss problem
    HI I have 01 chevy 4x4 5.3 4l60e transmission live data show the pcm is reading the oss to fast and shift to 4th gear at 10mph
    if I drive the truck 3 to 4 Miles it will start read the right speed and shift like it should and work fine till I turn the truck off then its back to shifting fast I have replaced the output speed sensor 2 with new sensors and 2 pcm no change replaced the wiring from oss to pcm no change dose the same thing
    Aug 2023
    SoCal
    458
    The computer thinks it is in low range. Either the range switch is bad or the wire is grounding out on the body somewhere.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Jan 2014
    SoCal
    1,567
    While I agree with TransGo Robert on this, it is important to include a read file ".hpt" and any mods done to the vehicle and a basic vehicle configuration
    Oct 2023
    3
    Quote Originally Posted by TransGo Robert View Post
    hi thanks for reply I using an autel mx808 scanner it show it in high range in transfer case 4wd works good when I go to low range scanner show it
    the scanner shows transmission oss at 747 rpm and vehicle is 6.21 mph. the speedometer is work right but for some reason the pcm is seeing
    the transmission speed faster then maken it shift to fast
    Oct 2023
    3
    Quote Originally Posted by dll View Post
    if I drive about 3 miles the pcm correct it self and start reading the right transmission output speed and shift like it should untill I turn the key off if key is off more 5 seconds it stops reading right again
    it like it loses it memory if I turn engine off and back to the on position keeping power to pcm it work fine and shift like it should
    Aug 2023
    SoCal
    458
    Sounds like you are on here but don't actually have HP Tuners so you can't post a log for us to look at it, am I right? Without seeing the data I don't think it will be possible to help if it is not the usual issue with the low range wire shorting to ground somewhere. If it was me I would cut it a few inches from teh computer just for a test to confirm it still does it.
    Robert Moreau
    TransGo
