Results 1 to 3 of 3
Thread: 04 2500 truck norris check
    May 2019
    new england
    74
    just wondering if someone could critique my tune up on my 04 silverado. completely stock except truck norris cam and valve springs.
    this is after a only a few flashes so there will be further checks.
    maf is failed but i also did a couple flashes for that and it's close.
    did idle trims for a few days.
    pretty much just a sanity check, i might lower the pe throttle a bit.
    log is towing a 3500lb trailer.
    wideband is through fuel tank pressure and matches scanner.
    thank you for your time.
    May 2019
    new england
    74
    just wondering if anyone looked by any chance. truck just feels lacking power. might have just already got used to it though.
    Mar 2022
    Indiana
    2,951
    The lack of power is due to your main spark tables. Pretty low timing where you'd be 'normal' driving.
