Results 1 to 3 of 3
Thread: Opening a CSV - No Data
    If a CSV is exported, opened & saved, it does not open back up in VCM Scanner.
    I've found that you need to go into the csv with a text editor and remove all the unnecessary commas, then save it, and then it will open in VCM Scanner.
    Has anyone found an easier way to do this? I don't use the export feature often, but when the scanner stops recording and I have multiple files for the same drive, I like to combine them using excel.
    • 2001 C5 Corvette (625rwhp - Procharger, LS6 heads, Torquer V2 cam)
    • 1991 Volvo 940 - 2JZGTE (600rwhp - PT6466, HKS 272 cams)
    Aug 2023
    SoCal
    452
    It is super annoying, I just open it with notepad and then select one of the long series of added commas and then just to a search and replace all. If there is a better way I am all ears. I often have to do this for PIDs that contain text and therefore can't be graphed unless you replace the text with numerical values.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Quote Originally Posted by TransGo Robert View Post
    Not fun!
