Results 1 to 4 of 4
Thread: Coyote tune
    Apr 2023
    2
    Coyote tune
    Hi all, am in need of someone to look at this tune , mainly the cam side. I?m getting bank2 exhaust codes p0390,p0394. Engine has had OPG and lower sprocket from MMR fitted, and bank 2 exhaust cam phaser. Have been through tinning a couple of times, engine idles fine but has vibration at around 1200rpm up, oil pressure is good,all cam sensors have been replaced, engine has about 10k on it and is out of a 2017 GT mustang, have done kam reset and crank relearn with no success. All wiring has been checked, wiring harness is Ron Francis wiring and computer is factory with pats removed
    Apr 2023
    2
    Bad timing, sorry.
    in the tune or valve ?
    Oct 2016
    Poland
    1,763
    Quote Originally Posted by Paul b View Post
    Timing, chain assembled incorrectly. You did OPG's you did something wrong.
