Hello all. I have an 06 6.0 in my '89 S10. The factory (plastic) 06 pedal will not work in the S10 because it bends directly into the trans tunnel. I ended buying a pedal from a company called PSI Conversions that was made for the Chevy C10 using an LS TAC setup. The pedal does work, however, the output is only 68% when pushed to the floor. I verified this on the throttle body blade position. My question is: can this pedal be tuned in HP Tuners? I see a couple settings in there for electronic pedal, but I'm not sure if that's what I need.
