Having issues uploading pictures for some reason, idk why. I?ll try again with the laptop later. Intake manifold is just the stock truck intake. Where in the intake could the IAT be relocated? The EVAP purge valve is still installed(not used) wondering if I could put it there somehow?
Having it in the EVAP will be an improvement since it's behind the throttle body. I think a better spot would be further down so that charge cooling due to water/meth evaporation can be tracked better. Something like right here: intake IAT relocation.png
Either way you'd have to figure out how to keep the sensor in without the boost blowing it out. Tight fit and RTV should work in the EVAP spot, but in one of those core plugs it might take JBWeld.
If you're onboard with IAT relocation do so then I'll make adjustments as necessary. No changes made right now. I can work on idle a bit (log STIT next one), but the rest is a fight due to OL and changing conditions. Some OL people actually run a cold weather and hot weather tune. Theoretically that shouldn't be needed if the IAT was reading the temp of air going directly into the cylinders. Same fight we're having.
Oh gotcha do I need to add that channel/PID to log it for ya? And I?ll be taking it for another spin on Wednesday. I have a short log I made but my laptop was about to die so not sure if it?s much use. I?ll upload it tonight
IAT reached 199 degrees sheesh! Sensor is out of the 2000's 1500's trucks also fyi. Black plastic, just like the one in the relocation video.
Perhaps i can trigger WM spray sooner?
IAT relocation helped. Actual tracks commanded a lot more consistently. Still there's the lean spike on tip-out after WOT.
WMI is off when when you let off the pedal and the throttle shuts. If you want cooler temps it's going to be either get an intercooler or lower the boost down. I'll repeat my recommendation of 8-10psi on this setup.
Later tonight I'll make a few adjusments.
