Results 1 to 4 of 4
Thread: 2013 Duramax with bad TCM needs to program new blank TCM can HP tuners do it
    Aug 2022
    1
    2013 Duramax with bad TCM need to program new blank TCM can HP tuners do it, this customer bought a new blank TCM and I was able to download it and the original. Can I write just the TCM to get him going instead of going to the stealer ship to be done, vehicle has previous tune that I didn't do and it may be a locked PCM I cannot read.
    Oct 2023
    Alberta
    4
    Quote Originally Posted by kulpba View Post
    Oct 2023
    Alberta
    4
    Not sure about the HP side. However you can sign up with the GM after market side and that with give you programing access to your Duramax you will need a pass through device that is J2534 compatible. One serial Number will cost you about $80.00. This will only rewrite with a factory spec or update the calibration.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    No it will not. Tech 2 or similar OEM style flash device is necessary to program a blank VCM
