I have begun contemplating the addition of Nitrous Oxide to my engine for drag racing. (BGE block with forged stroker crank, rods and pistons and 9.5:1 compression)
Is there a way to set up a tune so that when nitrous is activated, the appropriate amount of timing is pulled, but equally, if nitrous is not activated, ignition timing remains unchanged?
Or is it a proposition where if you don't activate the nitrous, you have to live with retarded timing that would support nitrous if it was activiated?
Thanks for any insight.
rich
