Just went through this issue on my 03 z06 (blower + blower cam), what fixed the issue for me was fixing a few different things.
-Set my base idle at 900 when car is warm
-Reenabled Rolling idle and set it to 950 across the board
-Tweaked my Idle Adaptive Spark control Underspeed table to look like this
-Throttle Cracker Enable Speed set to 2, Disable set to 1
- My throttle Cracker Table looks like this
-Rolling Idle Enable speed set to 2, Disable Speed set to 1
-Rolling Idle Airflow Adder, Copy the 1000RPM Column (closest RPM to your actual idle) from the Throttle Cracker and put those numbers into the Idle Airflow Adder Table, mine looks like this
-Adjusted throttle follower so the idle does not drop like a rock when clutching in and going into neutral, mine looks like this
Once I did these things, the low speed clutch-in stalling was fixed, and the idle dropping super low when going into neutral while rolling stopped as well. I'll attach my full tune also if you want to look at that.
