Results 1 to 3 of 3
Thread: 2014 dod deleted but didn't install required lock outs.
    Tuner Onomoto's Avatar
    Aug 2018
    Ohio
    120
    Friend of mine installed a cam in a 2014 V6 and got a btr kit with everything to do the dod delete minus the cam phaser lockout ( witch I told him to get). How fucker up is this ?
    2001 monte carlo swapped l67 on e85
    XP cam
    gen5 m90
    NorthStar throttle body
    speed daddy headers 3inch exhaust
    3.0 pulley
    lq4 maf
    cold air filter behind bumper
    60 lb injectors
    Tuning Addict
    Jan 2015
    6,813
    Depends on what Brian says. I've had customers running his stage 2 with no limiters whatsoever running the factory extreme phasing. As long as it will work with the engine running variable cam timing will work out better for mpg's and power. Just makes tuning harder cause it's more time consuming for one and you have to be more on your game at that point too.
    ~Greg Huggins~
    Aug 2018
    Ohio
    120
    The mechanic installed the plugs for the oil galleys but over looked the lockouts they were required.
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
