Originally Posted by
horsepowerguru427
Enable delta cyl air stock numbers are usually around .16(ish) if i recall right when the number increases it desensitizes the knock sensors more. i believe on my Cammed 5.3 in my yukon i had to move it up to .20 because i kept getting tip in "knock" at mid range throttle, but ive seen people run it up higher to disable BKR.
