Results 1 to 16 of 16
Thread: 2011-2015 Mustang V6 stock injector size
    Tuner in Training Aimless's Avatar
    Nov 2023
    Vancouver, BC
    11
    Correct me if I'm wrong. but by my calculation is seem that stock injector size on these engines are 28lb/h (at 3 bar/43.5psi)
    I got this value form the stock tune "Flow Rate High" value of 41.19lb/h at 64psi rail pressure. Now when shopping for injectors most injector are flow rated at 3bar/43.5 psi no 64psi. So now to correct for the pressure difference I do the following calculation.
    41.19/64*43.5 = 28 lb/h
    if I do same calc on the "Flow Rate Low"
    46.83/64*43.5 = 31.8 lb/h
    Did I read this information right or is hte "Flow rate" under the "injector control" is not what I think it is?
    I'm doing a turbo install, so need to get injectors that would low more than 28lb/h (at 3Bar)?
    Oct 2016
    Poland
    1,743
    Well they are too small and around 30lb. You need 50 or 60 lb at least. I can advise you on specific injectors that will fit, provide a data and a tune as we turbod a lot of Cyclones.
    Hit me up should you be interested.
    Nov 2023
    Vancouver, BC
    11
    Thanks veeefour, but I've already bought 2012 GT500 injectors. By my calculation these injectors should flow 53.6lb/h at 43.5psi?
    48.2/39.15*43.5=53.6lb/h
    My goal is not to make lot's power, I just like turbo is planning to run low boost of 5psi for starters
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by Aimless View Post
    Keep in mind Cyclones use short style injectors.
    Nov 2023
    Vancouver, BC
    11
    yes the cyclone come with "short" or "compact" size injector, and 2012 GT500 uses "standard" size injectors. From my research this is a common injectors to use on Cyclones and from watching a video I saw "standard size" injector fit into the Cyclone fuel rail.
    Is it wrong to put "standard" size injector into this engine with stock fuel rail?
    Feb 2017
    TX
    761
    How are you going to make the injector smaller?
    Nov 2023
    Vancouver, BC
    11
    Quote Originally Posted by Thatwhite5.0 View Post
    with a hack saw
    Just kidding. I'll try to post a link of the video of hte installation of "standard" size injectors into stock Cyclone fuel rail.
    From my understanding the stock "compact" injectors are retained and spaced out in the fuel rail by metal clips. The fuel rail itself is deep enough for "standard" size injectors and spacers won't be required.
    Nov 2023
    Vancouver, BC
    11
    https://youtu.be/GJhtkJ9jYns?si=iQxMeXVFZLA1IrPN
    Mar 2022
    Indiana
    2,938
    You're calculating incorrectly. It's not a proportional change.
    IFR2 = IFR1*SQRT(P2/P1)
    For your first example, flow at 43.5psi to 64psi:
    IFR2 = 28*SQRT(64/43.5)
    IFR2 = 33.96 @ 64psi
    Then the other way, 64psi to 43.5
    IFR2 = 41.19*SQRT(43.5/64)
    IFR2 = 33.96 @ 43.5psi THIS is stock injector size at 3 bar.
    Strange how the numbers you picked ended up with the same numbers for IFR, but pay attention that the IFR's are for different pressures.
    You can also use the handy tool in VCM Editor>Tools>Unit Conversion>Fuel Injector Calc
    Correct, go by flow rate high. Flow rate low is for the short pulse/non-linear region. The breakpoint is where high and low intersect.
    Nov 2023
    Vancouver, BC
    11
    Correct, go by flow rate low. Flow rate high is for the short pulse/non-linear region. The breakpoint is where high and low intersect.
    Awesome! thanks for that correction! I was able to calculate it by hand and with Fuel Injector Calculator.
    What I'm wondering how is that why when I open stock tune of 2013-2014 GT500 from the tune repository I don't see stock injector flow rates at 52lb/h?
    Everywhere online M-9593-MU52 injectors are labeled as 2013-2014 GT-500 OEM injectors with 52lb/h flow rate.
    Am I missing something?
    Mar 2022
    Indiana
    2,938
    Here's the datasheet for those injectors.
    I'm not sure why the data entered in the GT500 tune is like that.
    Also, I got that completely backward. AHISL (high slope) is what you use for flow ratings.
    Nov 2023
    Vancouver, BC
    11
    yes, and if I convert AHISL value from that datasheet from lb/s to lb/h. Like this 0.015851lb/s * 3600s/h = 57.0636lb/hr again I'm getting 57lb/h flow rate
    so AHISL in the MU52 datasheet does match "Flow Rate High Slope" in the repository tune.
    Still don't see where the 52lb/h value comes from
    haha yea I assumed you meant high when you typed low in the previous post, as you did calculation based on the "Flow Rate High" value.
    Mar 2022
    Indiana
    2,938
    There's all kinds of advertised flow rates.
    Here it's 52lb/hr:
    https://performanceparts.ford.com/part/M-9593-MU52
    Here it's 56lb/hr:
    https://www.vmpperformance.com/56-lb...Set-of-8-GT500
    It's trifling. That's why I try to find the datasheet. According to it they are 57.06lb/[email protected] and 60.15lb/[email protected]. At the industry standard 3-bar rating they are technically 60lb/hr injectors.
    The nominal rated flow isn't critical to get perfect (whether the injector is called 52 or 56). For example, ratings are typically for n-Heptane. Using gasoline the lb/hr rating will go up, multiplied by 1.04 to 1.07, due to gasoline being higher density. What is important is the actual data.
    The Hi slope means slope at Hi flow regions, beyond non-linear compensation. I get it backward in my head because the actual line of Lo slope is a higher slope graphically-speaking.
    I guess the point is pay attention to pressures and flow when spec'ing injectors.
    Nov 2023
    Vancouver, BC
    11
    got it! I just wanted to make sure I'm not misunderstanding something. But yea it all makes sense, just need to use values from the datasheets and ignore marketing material
    Nov 2023
    Vancouver, BC
    11
    haha veeefour instead of trying to scare people into paying for "expert" advice maybe try to contribute for a change. And thanks for the negative reputation review lol
    Oct 2016
    Poland
    1,743
    What?!? You gave me a negative feedback...not sure what your problem is...Im no trying to scare anyone LOL
    Sail away...
