Results 1 to 5 of 5
Thread: 2006 charger NAG1 shifting issues
    Jun 2023
    25
    2006 Dodge Charger RT with 392 engine swap
    Using NAG1/A580 transmission & original wiring harness.
    New:
    -Transmission
    -Valve body with conductor plate & sensors
    -TCM
    -Rear CV axles
    -Rear ABS sensors
    -?Shift electronic module?
    -Inspected wire bundle from pcm to tcm
    (My last thought is possible bad pcm?)
    Transmission shift points are very late/delayed from 1-2 and 2-3 and the transmission will not shift past 3rd gear on its own. If allowed to shift itself to third, it gets stuck in third until car is restarted. All 5 gears can be utilized ?auto stick? without issues unless put back into auto mode. For example, if driving in manual 5th and I put the transmission into auto mode, it?ll jump down into third no matter the speed.
    Using HP tuners, I have tried resetting the transmission adaptives, preforming an ?EGS5X init? procedure, verifying and entering proper tire diameter, gear ratio, etc into the computer
    When the transmission gets stuck in third, I get a P0733 ?gear 3 incorrect ratio? code. That is it for codes.
    Also- the transmission will work and shift through all gears if I go into hp tuners and disable ?traction control? which disables the abs and displays both abs and brake light on the dash. However, I have no abs codes.
    I have also tried reuploading the tune which was downloaded before the car had any issues. Any help would be greatly appreciated - thank you!
    Aug 2023
    SoCal
    452
    Sounds to me like you have the wrong rear end ratio entered in there. It would help if you included your tune and a log of it in automatic mode where it sets the P0733.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Jun 2023
    25
    I wish it was that simple I got the car in the air and counted how many drive shaft rotations were needed for one full rotation of the wheels. It was just under 3 and these either came with a 2.62 (rt), 2.82 (rt), or 3.06 (srt). I tried putting all 3 ratios in and anything besides the 2.82 makes it worse.
    Aug 2023
    SoCal
    452
    Quote Originally Posted by QuentinC View Post
    Post the tune and log
    Robert Moreau
    TransGo
    Jun 2023
    25
    Transmission no shift past 3rd.hpl
    Above is log file - I don't see any info on the transmission I'm new to this so not too sure if I didn't record that data or I just cant find it..
    I also can't seem to attach the tune file here for some reason it isn't allowing it. Do you have an email I can send it to? Thanks for your help it is much appreciated
