Results 1 to 2 of 2
Thread: hello everyone. looking for some help with a 2017 gmc 2500 6.0l
    Apr 2013
    Recently a pal of mine purchased a d-1sc procharger (used) and we installed it on his 2017 gmc 2500 6.0l truck. at the same time we removed the variable cam installed a stock/boost fixed cam did a valve job and head gaskets. I have an lsa map sensor and 56lb injectors also. I need some help with this gen 5 truck. im over my head in the tuning world and some reccomendations would be great. I have pulled the base file off of the truck and can update. I have reached out to a few tuners (and pro charger directly) and haven't gotten much help. even if someone had a gen5 6.0 boost tune I could look at that would be something.
    Tuning Addict
    6,813
    Install the baro breakout? Tune the VE and MAF like normal. You really need to adjust background tables since it's a truck, but see what kind of throttle control you have first.
    ~Greg Huggins~
