Results 1 to 2 of 2
Thread: crackle tune, how to increase intensity without shredding cats
    Jul 2019
    30
    not really sure how to word what im asking, but basically i want to make the dfco pops more intense but without risking blowing out my cats and sensors. right now i have it set up so at lower rpm its a soft burble and higher rpm it pops a bit, which is exactly what i want, but i want the higher rpm range to be more of a snap than a "pah" (but not an obnoxious gunshot) because it just kinda sounds bad and like there is a problem with the engine. i have long tubes and high flows so the cats should be a bit safer than the stock cats due to distance, but i still dont want to risk it too much.
    sd tune daktah.hpt
    side question: is there also a way to increase engine braking while still under the dfco transition while coasting but before it actually cuts fuel?
    2013 Camaro 2SS 1LE 6MT (E38)
    Mar 2022
    Indiana
    2,954
    Look into a Corvette file. They have a nice burble on decel from the factory. Won't have to worry about damage with it. Look at what's done for spark at high rpm/low MAP and DFCO.
