Results 1 to 4 of 4
Thread: Injector scaling
    Jul 2021
    3
    Injector scaling
    Question abount injector scaling I have a later e38 with the 127lb limit. Fitting a set of 1500cc injectors to a ls3. I know about the double stoich half IFR method. But is it possible to halve the injector flow rate and use the (Injector flow multi vs volts table) at 2 to make up for the half flow numbers in the IFR table? As if i do it this way i ill get the injectors within the ECU limits without worrying adout any other issues that crop up with the double stoich half ifr method.
    Jan 2014
    Australia
    1,984
    there is no other issues with the double stoich, have inj flow and halve ivt terms and ur done that easy, just use lambda for fueling, u can try the other table if u want but they dont always work in all OS
    Nov 2006
    2,745
    There is no need to complicate it.. Really no issues if you double stoich and half IFR
    Tuner at PCMofnc.com
    Tuner in Training nathanhine1977's Avatar
    Oct 2019
    Darwin Australia
    38
    How do you get around the hard limits on an E40, I have a set of 1500cc injectors, but as far as I can see they are just to big for the ECU???
