Results 1 to 17 of 17
Thread: how to make 100% pedal equal 100% throttle
    Aug 2023
    18
    tuning a procharged 09 6.1 srt8 working my way up slowly adding timing and fuel but I can't seem to find how to make the throttle go wide open when pedal is at max voltage .has a ported stock intake to except a 95mm throttle body but same with the factory one .wot gets you from 50 to 70% ish .
    mpvi3 and newest software just downloaded .. any help would be great thanks
    Aug 2006
    5BA8
    3,269
    Hang on I got this.....
    How is anyone supposed to help without seeing a data log and tune file?
    EFI specialist
    email=[email protected]
    Just a guess but, throttle relearn? But yeah, listen to @edcmat-l1 post up some info
    Aug 2023
    18
    Quote Originally Posted by dodgeboy View Post
    I have done relearn both with hp system and the factory hack 20 sec deal with 0 results. I thought when posting that this was simply a setting outside the airflow/throttle body section of the tune that someone would have knowledge of ..I will pull data log and post asap thanks for the replies
    Aug 2006
    5BA8
    3,269
    Quote Originally Posted by baracuda31 View Post
    Data log and tune file. There is no "click here for 100% throttle" button. For one thing it'll never go 100% WOT. Nothing late model will.
    EFI specialist
    Aug 2023
    18
    file:///C:/Users/court/Downloads/wotforforumpost(1).hpl
    Aug 2023
    18
    file:///C:/Users/court/Downloads/102923neswestcorrectedfromwothmefromplymouth2fromw ot103123rpmupplus3percentwotenrich2misxturex2.hpt
    Aug 2023
    18
    if either one of these or both dont open correctly i apologize i am still figuring out this forum and software and tuning for that matter with a laptop ..lol
    Aug 2006
    5BA8
    3,269
    First thing is, click on "go advanced".
    Then in your post tool bar, click the paper clip icon and that will take you to the attachments window.
    Then you can attach your tune file, data log, screen shots, etc. Screen shots need to be kept pretty small. Jpeg works the easiest. Just save any pics or screen shots as jpegs.
    EFI specialist
    Aug 2023
    18
    log and tune
    here is log and tune files
    Nov 2019
    227
    Don't see an issue in your log. Your "accelerator pedal position sensor" is hitting 3.83V and your "throttle position sensor" hits 3.80V very shortly after.
    These are maximum values on FCA systems and thus you are actually getting WOT at the TB.
    The reason you are "only" seeing the "relative throttle position" hitting 76% is because it's scaled to 5V max as an SAE parameter. Thus 3.80/5 = 76%.
    I'd be more concerned about the KR its pulling in 2nd and 3rd gears in that log. Up to 9 degs!
    Aug 2023
    18
    yes the retard was because I didn't have the blended fuel in it .. I filled up with regular pure 93 .usually have 1/2-1/2 with racing fuel and it doesn't trigger any or maybe 1-2* if it's a 2nd pass on warm day . I drove it to get a fresh log this am and didn't even think about it
    . I read about the 5volt reference and 3.81 throttle voltage on another thread earlier and I'mgoing back thru past logs now to verify ..im almost certain the percentage at wot in middle of several wot runs dropped into the 50s . Asa I have verified if it is will post those logs as well thanks for response and all the info
    I would, and I am not professional tuner but, I would save your current tune for race fuel and then pull some timing, log KR get it to 0 or close and save it as a "93 Tune"
    Aug 2023
    18
    turns out I found my own answer to the post .. and you are right .. anything over 5 spark retard and the computer is using the throttle to protect the engine .. ran it today whenni went to check then mail and I will post the screen shots . but I was still wot at 3.83 Asa it hit -6 and went on to -8 it dropped throttle position to 55% which I known now 76 is actually physically 100% open .. so I'm gonna redo the timing on this tune and save it as pump gas tune and run the original when I have the blend in there to control knock retard .. thanks for sll the feedback guys .. feel like a Newby on yhis car csn walk across the yard to the 340 demon and everything on it is unconscious for me ..lol
    Jan 2014
    SoCal
    1,565
    Correct me if I'm wrong but don't you take the 15% base idle throttle from the 100% throttle theoretical and get the 85% that you are getting on your data display.
    Jan 2022
    904
    all that matters is the voltage
    Aug 2023
    18
    tweeked the wot timing and got kr 0- and 1-2 in a few spots and the throttle now stays constant all the way thru on that tune.. so the kr someone pointed out earlier being a concern regardless of the throttle , ended up curing the other once I corrected it ..thanks for the input
