So got on the dyno and did some playing with the timing tables and actually gained some power by reducing the spark and afr was spot on 12.7-12.9 didnt have it plugged into the log this time was using the dynos log. I was shocked I didnt see much KR after this last revision. But i mean it is running great so just want thoughts on anything that should be changed for safety, or if you see anything that stands out that should be fixed. It does feel good made 569 rwhp and 520 rwtq with this tune and cruises really nice as well. The log is after the dyno and doing some changes while cruising and going wot here and there to get the part throttle and off idle tuned in.
