I have a 16 GT 350 this car has been an absolute nightmare can someone please help me!!! i bought this car brand new in 2016 and since then its gave me nothing but problems. i am on my 3rd engine that was covered under warranty. car is no longer under warranty though i dont believe it to be a bad engine at wot it will hesitate between 5-6k and will resume fine all the way until redline,i have replaced the intake, coils, injectors, wiring harness, spark plugs gapped to 28, and new crank sensor and i did do a neutral crank learn. and nothing will fix the issue. when in first gear or second issue does not happen or if i have redlining the car and do a quick shift to keep it above 3k rpm it also does not have an issue. i have also seen while ideling the vehicle does misfire and i can actually watch the misfire counter go up. i am not very good at reading pids but i did notice i got a misfire at wot and timing dropped to 3.5 deg. could someone please review my scan and tell me what they think? also my transmission is a tremec it is not the orginal it has a slip yoke instead of the drive shaft flange so it is not the loose nut tsb i am getting no codes. 1st part and last misfire madina.hpl
