Results 1 to 3 of 3
Thread: very big difference in AFR commanded vs Actual in wot
    Apr 2023
    Italy
    42
    I really don't understand
    my swapped LZ4 with E38 has a big difference in wot between AFR commanded vs acutal read with a wide band sond......
    should be 12 and is 14 or even leaner.......
    engine is swapped and I bought the car in this configuration (no speed sensor, custom exhaust.....)
    all A/F ratio is generally lean but behave strange
    Paolo
    Grifun mid engined V6 3500 LZ4 manual trans
    13,574
    I'd manually verify that you have good fuel pressure first. If that checks out then I'd honestly probably just add 10-15% to the MAF curve in the desired Hz range. If the actual fueling starts to match the commanded, then you know where you need to work on it.
    Apr 2023
    Italy
    42
    I agree this is the right way to proceed !
    Paolo
    Paolo
