5.3 ls turbo can get to run
so as stated i built the car had bought some cheap stuff in the process have since gotten rid of said cheap stuff now i can't get the car to run seems like the injector data is weird as far as the flow rate vs Kpa table if i input the correct data the car will start and die immediately with or without throttle but if i cut that flow rate in half i can get it to idle but runs weird not right there deatshwerks supposed to 88lb/h injectors but for whatever reason on the side of them say 1000cc I'm trying to figure out to post the tune as of now i had the car running great prior but can't even get a good idle now
current camaro tune.hpt
