I do not understand what TCC slip should be on this setup so I'm looking for input on this issue. The trans oil seems to get warm pretty quickly.
2003 Tahoe, 32" tall tires. 3.73 gears (I think)
Transmission is a 4l60e, fresh rebuild, trailblazer 4.2l torque converter, Beast sun shell, Corvette servo, Sonnax pressure regulator, Transgo shift kit, 30000 GVW external trans cooler.
The Engine is a 5.3 lm7, TSP Low Lift Stage 2
Camshaft: 212/218, .550"/.550", 112 LSA. Cylinders bored to 5.7 3.898 specs, flat top pistons. TBSS intake. Stock manifolds.
There's a small leak in the top (hot?) cooler line. ( I will correct this ASAP). Other than it getting too warm to my liking, the transmissions seems to run fine. This is the 2nd time I install this transmission and I don't mind the work but I don't want to toast all of the internals again.
Test run after transmission rebuild 11-26 tcc slip 1.hpl
