Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Looking for injector data
    I have a set of FoMo V4B1A injectors. Dark blue. I think they are stock 2013 Ford Raptor 42 lbs injectors. Anybody have details on these so I can use, or are they not good for LS6 with small cam, headers, and intake?
    Nov 2017
    Indiana
    329
    Quote Originally Posted by Red01Z06 View Post
    If you didnt get info with the injectors when you bought them, then i doubt you find it in here. I had a similar issue the other day with some Ford injectors i needed data for. They were being used on a SC LT1. The general concensus was that no one in GM section had any data for ford injectors. Short of sending them off to be flowed and tested, then youre gonna have a hard time finding what you need.
    "I don't care how it runs as long as it chop chops at idle"
    Mar 2022
    Indiana
    2,954
    Post your tune I'll update the file with the info.
    Confirm the part number. 2013 Raptor uses 47lb/h P/N M-9593-LU47. V4B1A is also coming up as 24lb/hr injector used in the Navigator. Are there any more numbers on the injectors?
    Here are pics of injectors. I think they are 42# at 64psi?
    Mar 2022
    Indiana
    2,954
    Yep that's what I'm seeing. It's more like 43.2lb @ 64psi. Post the tune I'll update it.
    Ok, but I still use Ver 2.22 with serial adaptor:Red01Z06-New.hpt
    MAP (kPa) 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
    Injector Flow (lb/hr) 41.12590003 41.38220911 41.63694044 41.89012278 42.14178407 42.39195139 42.64065103 42.88790853 43.13374869 43.37819561 43.6212727 43.86300275 44.10340789 44.34250969 44.58032911 44.81688657 45.05220194
    I think these are/should/maybe be my Flow Rate vs KPA
    Nov 2006
    2,742
    you'd be a lot better off buying something with good data. Are you even sure the spray pattern on these is proper? Using a LSA injector in a NA application and having stumbles/misfires is a good example of why you need to be careful about this.
    I can convert ford data if you can find it to GM data. Search Ford injector data to see what the format would look like
    If you don't update short pulse adder and offset you are going to have tuning issues.
    Tuner at PCMofnc.com
    Stock injector for the 2011-up Ford 6.2L is the AL3E-F7A
    32 lb/hr @39 psi (4.14 g/sec @ 270 kPa)
    25? Gamma Spray Angle
    USCAR Connector
    Long Body Style
    EV6
    Part Number:
    Denso 297500-1850 / 1850
    Ford AL3E-F7A / AL3Z9F593B
    Motorcraft CM-5195
    Autoline 16-2080
    Bostech MP2208
    GB Reman 822-11218
    SMP FJ1166
    Mar 2022
    Indiana
    2,954
    I'm having more trouble than I thought with this. The data in the Ford tunes makes no sense because the Hi and Lo slopes are reversed. Can't find a manufacturer datasheet, either. I'll work on it some more later tonight.
    Thank you. I thought I was crazy seeing that also. I had high hopes thinking I could just of download stock Raptor tune and getting details....
    Nov 2017
    1,466
    So are these Amazon or Ebay injectors?
    Neither, I own a 2013 Raptor also. It has the Hennesy Velociraptor 600 package on it and these were my stock ones. I want to install a Fast 102 intake in my 01 Z06. I currently use fat body 36# SVO injectors in the LS6 intake. They will not fit in the Fast. Before anyone goes nuts and says the 102 is not needed, it looks cool and later, when I do put a supercharger on, I will be ready.
    Mar 2022
    Indiana
    2,954
    I'm almost finished with it. Had a lot going on last night. All I have to do is the SPA and it'll be ready.
    You rock, thanks.
    Sep 2021
    475
    Can we add this to the injector data repository?
    How is it coming? Need anything from me?
    Have I lost ya?
    Mar 2022
    Indiana
    2,954
    No. Tonight I'll get back to it.
    Mar 2022
    Indiana
    2,954
    Idk what is wrong with me that I can't figure this out. I'll keep at it because it's bothering me.
    Mar 2022
    Indiana
    2,954
    Alright here's what I came up with. Data is in the attached. Don't forget Fuel>Transient>Min Fuel Milligrams.
    Let me know how it goes.
