Results 1 to 13 of 13
Thread: Wiring harness question
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Does anyone know where I can get a 2012 GMC Engine harness diagram ?
    I have looked at a lot of websites and it always gives me some other info or a 100 other models that I don't care about. I need to find out why my harness has a few problems
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2017
    1,464
    Alldata or www.acdelcotds.com
    Jan 2014
    SoCal
    1,562
    Are you looking for pinout on the PCM? Or the entire harness assembly wiring. I will help you if you need the pinout but the entire harness assembly is a lot of work. Well over 40 pages. Send me your VIN and I'll get you the pinout. Other than that as gtstorey said....
    AC Delco tds is $22 for three days. I can't get you all those wiring diagrams and pdf them to you fr that.
    Jul 2012
    Florida
    1,459
    Thank You!
    Jul 2012
    Florida
    1,459
    Quote Originally Posted by TheMechanic View Post
    Thanks for the pinouts. I had a temp subscription to alldata, and thought my problem was the pcm. So I didn't print out the diagrams. Got a new pcm and same problem. All the injectors are wide open at key on. 12v across the injector plug pins. so, now I have to figure out WHERE my harness is messed up. I will get another subscription and download the diagrams. Cheaper than a new harness.
    The harness is a stand alone internet harness with no diagram. The engine is in my 2000 Camaro. No BCM or any of that stuff.
    I guess the correct way to put it is that I have ground applied 100% of the time to the injectors. All of the ground wires are pinned to the correct number in the ecm plug. I have the whole harness unplugged now. I just don't know where to start looking without a diagram.
    Jan 2014
    SoCal
    1,562
    Your best bet is to go through all of the schematics for engine and trans and print to pdf. That way you will have them as a better printable reference.
    Jul 2012
    Florida
    1,459
    Thanks, I am getting ready to sign up for a few days
    Jul 2012
    Florida
    1,459
    I got the schematics. My store bought harness is bad. Sent it back.
    While I was searching, I ran across a video on Utube that showed starting a LS with a stock harness. I happen to have one and the truck fuse box. I hooked it up and it fired up. That harness cost me a lot of time and money. China
    Jan 2014
    SoCal
    1,562
    It is worth while to at a minimum if you buy the cheap china garbage to do a thorough testing. That includes getting a few appropriate pins and ohm out all of the wires. Also right before pull on each wire pretty firmly to ensure the terminals have been crimped
    Dec 2019
    MS
    567
    haha. ive got a buddy that buys a bunch of them chinese wiring harnesses then spends most part of a day trying to trouble shoot them.
    Jul 2012
    Florida
    1,459
    Bad thing---I didn't know I was buying a China harness. And you are right about pulling wires. Three pins in the X1 plug were not seated. Even after I pushed them in, it didn't make any difference. Lets see, so far it has cost me hours and hours of trouble shooting time---buggin' tuners on here---, three oil and filter changes (gas in oil), another e38, licensing the new e38, rigging up the truck harness, electrical parts. And no way to get any money back for all of that. Disgusting!
    Jul 2012
    Florida
    1,459
    RDFI
    I hope he quits buying them
