Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: New to tuning. Intake, manifold and throttlebody swap L 86 2016 Chevy Silverado.
    Sep 2023
    16
    Can somebody please help me navigate to HP tuners how to get my truck out of limp mode because of the new throttlebody
    Tuning Addict
    Jan 2015
    6,813
    Something wrong with the tb, wiring or ecm if it's going into REP because of a tb code. You sure it's not a pedal code?
    ~Greg Huggins~
    Sep 2023
    16
    I did a L 86 intake and throttlebody swap and I’m getting a 2101 code
    And the truck ran fine before I did the swap. It just came off the Dyno last week.
    Tuning Addict
    Jan 2015
    6,813
    That's a motor control circuit code meaning the motor is unable to move the plate when commanded to do so. Most likely the tb, unless it's heavily carboned or you have ice or something like that formed freezing the plate in place. I've also seen tb cleaner get into the electronics via the throttle shaft cause this code but you can almost always blow air or take apart and clean out then let dry to get it back operational. Sounds like yours is dead in the water.
    Other codes can set because of the tune, but that's only if the throttle is opening and dancing away from pedal command too much.
    ~Greg Huggins~
    Sep 2023
    16
    It is a brand new Katech 87 mm ported throttlebody could it possibly need a tune or is it something wrong with the throttlebody from the company that made it?
    Jan 2014
    SoCal
    1,565
    Quote Originally Posted by Wmbland View Post
    Did they tell you it would be good to go in your specific application/ECM, OS, Pedal? If yes and everything worked before you got a defect. If not they should replace it with one that fits, form and function.
    Sep 2023
    16
    Yeah, they said it should work with no problem. I shouldn’t have to use HP tuners to fix it. They’re gonna send me another one and I have to send this one back. Thanks everyone for the help.
    Sep 2023
    16
    well got my Silverado Tuned after the new throttle body. It worked for about a month till my alternator killed my battery. now idle surges in park. Had to replace both battery and alt. I did a data log and i am going to try and figure out how to put it on a post
    Sep 2023
    16
    march 14 145 pm log.hpl hopefully this worked this is a log file from this afternoon. 2016 silverado stage 2 L83 tsp cam and a ported Katech 87 mm throttlebody , stainlessworks longtube headers flowmasert outlaw dual exhaust ,upgraded rocker arms and a L86 intake manifold
    Tuning Addict
    Jan 2015
    6,813
    How was the TB and intake manifold addressed in the tune? If whomever tuning it changed the tb size then it was most likely messed up. There are background settings that have to be changed for it too. Then unhooking the battery or rather killing it would have reset all of the learned values, so it might need the VE and torque model both corrected. You're not logging enough to tell anything, but I'm willing to bet all of your VE is off. I can your torque model is from your timing. Fuel is also pretty far off with it adding 10%, which again if the VE was right and things were good before the battery points to the VE and torque model being thrown off.
    ~Greg Huggins~
    Sep 2023
    16
    I am going to get a better log here in a little bit gotta go to the store. I appreciate all your help. I have watched so many videos on how to do tuning it hours to learn just a little bit, but I’m willing to learn that’s for sure.
    Tuning Addict
    Jan 2015
    6,813
    Might want to post the tune too
    Jan 2014
    SoCal
    1,565
    Since you had a battery/charging system issue your first course of action would be to perform a throttle body/idle relearn.
    Sep 2023
    16
    I Thought i should do that. I did a better data log last night with a different channel config.https://1drv.ms/u/c/dd206c9237979ed0...Y5Ecw?e=lyQDgT i hope this is rite. this is the tune.
    Sep 2023
    16
    This is the data log.https://1drv.ms/u/c/dd206c9237979ed0...csiwg?e=YgfW3X
    again i hope this works. trying to remember computer stuff after not playing with them for at least 10 years .
    Nov 2017
    1,466
    Most people are not going to follow a link for a log or tune. You would be better off if you attached a tune within a post.
    Sep 2023
    16
    Ok. I have to figure out how to do that thank you I’m learning
    Sep 2023
    16
    Surging idle after battery killed by alt and possible bad tune
    march 15 surgeing idle.hpl
    now that this worked i'll send the tune next
    Sep 2023
    16
    This is the tune. tuned read march 13.hpt
    Sep 2023
    16
    I thank everyone who is and will help me thru this process
