Hello,
I have what I hope is an easy question that I can't seem to get a straight answer for.
I have a 2019 Ram 1500 with the 5.7L engine and I had an MDS disable tune installed a few months ago. Simply put the best money I have spent on my truck so far!
When the tune was created I had 3.21 gears in the truck, and now I want to install 3.92 gears. My tuner is remote, and I don't have HP Tuners... so I can't modify the PCM tune that was installed. I do have AlfaODB and I can update the axle ratio setting in the BCM... but I'm curious whether or not the PCM will see this new value and use it, or if I need to send in the PCM tune for an update.
So simply put, I'm wondering if anyone out there has changed axle ratios after installing an engine tune, and if so, did you ever go back in and update the engine tune or did you only change the axle ratio in the BCM.
HP Tuners support said this:
With our gear and tire wizard in the VCM Scanner, you can make the BCM change in the controls and special functions. Changes will then need to be made to the tune file in the VCM editor to accommodate the new gear ratio
To me that seems to point to a change also needed in the engine tune... but I don't understand why it would be needed.
