Results 1 to 4 of 4
Thread: Tuning with TiVCT deleted
    Mar 2022
    6
    Just curious what the standard procedure on a Gen 2 PCM is as far as settings when tuning an engine with no TiVCT. Large cams, high compression make effort N/A deal? I have an excellent tuner already. I am just asking to try and grasp the concept myself. Pondering whether if I am at the point of needing an aftermarket ECU.
    Thank you!!
    Oct 2023
    6
    pm me, I'm currently tuning an imrc deleted/tivct deleted BIG CAM 2.9 Whipple 130mm throttle body, 10:1 built motor.
    there is a lot that goes into this set up. I'm still grasping the mapped points and how they activated and deactivate. there's a post here from hp tuners that once imrc/tivct are turned off only mapped point is used. However Im finding that not to be true.
    Oct 2016
    Poland
    1,744
    Quote Originally Posted by PDub6s View Post
    Thank you!!
    You dont need aftermarket ECU - we did a few few projects with different engines running on Coyote PCM.
    Termi Cobra engine running with 6r80 on F150 PCM for example - this is 100% doable. Hit me up.
    Mar 2022
    6
    Wouldn't the engine stay in one mapped point since the cams are fixed?
