Results 1 to 12 of 12
Thread: 2007 surburban
    Nov 2023
    10
    2007 surburban
    i have 2007 suburban with a HP tune in it,the computer went bad replacing it with new flagship one plug and play. can i pull my tune off with hp tuner and reload it into the new computer
    Nov 2017
    1,527
    You will want to copy the changes from the old tune to the new tune read from the new ECM. The write calibration back to the ECM.
    Nov 2023
    10
    So are you able to help me program as well
    Nov 2017
    1,527
    No
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,278
    we would NOT recommend flashing a file from one ecm to a different ecm, you do so at your own risk.
    Nov 2023
    10
    What your recommendation after install my new ecm
    13,576
    If your computer went bad, how do you plan to read the tune off it?
    A bad computer isn't going to let you read it 99% of the time.
    You can install your new computer and start tuning it yourself.
    Nov 2017
    1,527
    Could have been something like loosing a ground on a sensor or O2 heater.
    Nov 2023
    10
    well im getting transmission code low circuit low solenoid, discover problem in ecm vehicle still drive able just has transmission code
    Nov 2023
    10
    when you say tune myself i have hp tuner but very little experience
    Nov 2017
    1,527
    Sounds doubtful that you have a bad ECM. If it is, sounds like it’s probably still readable.
    HP Tuners Support
    (foff667)
    28,278
    read new ecm, license, & tune away using the file you read and licensed from the new ecm. This is also outlined in the help file.
