Results 1 to 2 of 2
Thread: dodge 300c srt8 2010 - ngc4 pcm vortech v3 6lbs.
    Sep 2023
    1
    i am having a really hard time tryin to tune my car here in brazil.
    there are no tuners that i know of here that uses hp tuner.
    the car or a 300c srt8 2010 with a ngc4 pcm.
    running e95% and a vortech v3 with 8 pound of boost.
    i have bought a 3 bar map sensor on aliexpress, the only place that i found it, and changed the airflow setting to 3 bar map sensor.
    Map Sensor Linear: 61.85 kPa
    Map Sensor Offset: 6.80 kPa
    Map Sensor Offset: 0.12 V
    sensed map is off
    baro learning is on.
    the barometric is showing 140kpa with the car shut off.
    the car gets the error codes.
    p0129
    when i start and shut of the ignition 6 times its goes away anda appears
    p0171 and p0174
    please help!
    Oct 2016
    Poland
    1,743
    No problem, Ill can take care of it. Tuned few setups like this - hit me up, contact detail in signature.
