Hi everyone. i want to know if anyone have a tune file for run with e85 on 2011 5.7 ram. Or if it's possible to have a stock tune of a 2011 4.7 flexfuel ram. Thanks
Click on the "OS" button just to the left of "Engine" up there in the upper left portion of your main tuning page. For many of the rams there is a Flex Fuel Patch that you can enable that will set-up many of the tables needed to run E85. Follow the instructions it gives you exactly. This will get you started, but just understand that there will be other tables that you will need to make adjustments to in order to get everything dialed in right, particularly under the "Fueling" tab, such as changing your stoic in a couple places from that of gasoline to the stoic for E85 (and this will vary depending on what you find your pumped E85 to actually be when you test a sample from wherever you get your E85) and adjusting your start up fueling and injector pulsewidths for the switch to E85 and a few other table adjustments.
2016 Ram CCSB Forged NA 396ci Stroker
+2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
3800 stall/Det Tru-Trac/410 Gears
I dont have anything in os menu.😭
