Results 1 to 5 of 5
Thread: 2011 ctsv vve tuning help
    Car is running on a MAF only tune right now. trying to learn and understand vve with this gen 4 platform. i failed maf reset fuel trims and disabled stft and logged and this log is what i got. can someone please explain how this vve works? im more famialir with the copy and multiply by half method in gen 3.
    i copy table from the log and go to paste by special/multiply by percent, i then click calculate coefficient and this message pops up
    (the following zones 17,23,29 are not supported by the data provided. consider changing your axis to include the range of all the zones boundaries for the calibration calculating the coefficients with incomplete data could result in undesirable date)
    i click yes to see what it does and my vve map goes someone please help on what im doing wrong.can someone explain it dumbed down please
    Tuning Addict
    Jan 2015
    6,815
    I haven't looked at the tune but just from your name I'm assuming a ctsv? This means it's got it's zones setup to read into boost. You have to change the map axis by clicking on it and then clicking on the middle row to show a 2bar map VVE table. This will then match the zones as defined in your calibration so no errors should pop up at that point. Also go back to a stock VVE table and restart from there as when you hit OK it changed it to a 1bar format = not good in your case
    ~Greg Huggins~
    Tuning Addict
    Jan 2015
    6,815
    Here, these are what I'm talking about.
    ~Greg Huggins~
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    Also, take a look at this thread:
    https://forum.hptuners.com/showthrea...-the-Same-Time
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
