Results 1 to 3 of 3
Thread: 6l90e tcc settings for dummies LOL
    can someone help explain what to adjust with my tcc settings? looks like my tuner left slip still at 20 rpm.
    tune and driving log attached
    2011 cadillac ctsv
    roughly 650 crank hp
    stock converter
    Mar 2022
    Olathe Ks
    87
    They left the lockup function on in 3rd - 6th gear....
    So gears 1-2 just ignore, it'll never lock up
    I'd get rid of lockup altogether in 3rd gear - it's kinda silly to have it in normal/performance situations.
    Then drop the slip in 4th-6th gear down to zero... I left a little bit of slip in at low rpm/low power and scaled it from 5 down to 0...
    You could also benefit from keeping the transmission in the lower gears a bit longer as it upshifts at mild acceleration...
    Of course you will have to change the lockup engage/disengage accordingly
    HTH
    Aug 2006
    5BA8
    3,253
    Nothing wrong with leaving the slip tables alone in most apps with a stock converter.
    EFI specialist
    email=[email protected]
