Results 1 to 14 of 14
Thread: older e38 running bosch 210s
    Jan 2023
    5
    just got done installing new setup and i am trying to get my injectors to work with setup if anyone can help put.
    ls3, bosch 210 injectors, e85, stage 4 boost cam, t6 90mm turbo 8lbs of boost. 4l80e 4000k stall 456 gears.
    will pay for help or remote tune
    [email protected]
    Nov 2017
    1,464
    Did you get full GM data for those injectors?
    Jan 2023
    5
    i did not, purchased from texas speed
    7,643
    Those are CNG injectors, not recommended for gasoline. You will have issues later even if you find accurate data and manage to get it input correctly. I think everyone who has bought them has soon switched to something else.
    Nov 2017
    1,464
    Return them or sale them and get injectors that come with GM data.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    You can use Injector Dynamics data to set up your Injectors. However, the older E38 is limited to 63.5#. You can do the double stoich method and get 127#, but that doesn't get you close to the 240# @ 58psi on the Bosch injectors. You will have to modify a bunch of tables to get them to work. Easiest way would be to get a 2009+ E38 that will allow you to do the double stoich and use those injectors without much trouble. I have my tune like that. I can send it to you if you like. I have no idea if you can swap the computers and use the same harness. Check online at LT1 swap and see if the pins are the same.
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2006
    2,742
    Some 1000's or 1300's would cover that and be a lot easier to deal with the ECM limits.
    Tuner at PCMofnc.com
    Aug 2006
    5BA8
    3,253
    Like trying to fill a shot glass with a fire hose.
    EFI specialist
    email=[email protected]
    Nov 2006
    2,742
    Ive proven several times on the dyno an injector at a 80% DC will make better power than an oversized one that runs maybe 40% at WOT.
    Jan 2023
    5
    i got it to idle, drove it around the block. i added log and updated changed thanks
    Jan 2023
    5
    Quote Originally Posted by Lakegoat View Post
    i have a newer e38 but was told to use currently since im running 4l80 and not a 6l80
    Aug 2006
    Arizona
    244
    A lot of people don't understand this when I explain this same exact thing to them. Fuel control can also have a huge effect on high rpm power.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Jul 2012
    Florida
    1,459
    Quote Originally Posted by lsx_69c10 View Post
    Sorry, I did not understand what you meant. I am running a 4L80 also.
    Nov 2006
    2,742
    Quote Originally Posted by STAGEUP View Post
    I don't think its a control thing. The AFR will be spot on either way.
    I think it has to do with how the two atomize.
