Results 1 to 8 of 8
Thread: E41 ECM Read Failed
    Dec 2023
    E41 ECM Read Failed
    I have a 2019 L5D and the MVPI3. Everything is connected properly, and I am connected to the internet. When I try the initial read, the VCM Editor fails to retrieve flash data. I have tried different PCs and gotten the same error. Also, I attempted to read the ECM with the TDN app and i got a "Convert seed to key, failed" error. I have submitted a ticket already and am waiting for a response. Does anyone know what will cause the editor to fail to retrieve the flash data from HP tuners?
    Far as i know, these are write only ECU's. So based on your vin HPT generates the stock file for you to start. So its not reading out your calibration per se
    As for why it fails, that i am unsure and HPT would be best to address i'd say.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Dec 2023
    3
    GM e41 ECM upgrade kit has to be used with MPVI3 to work on cars such a
    Jan 2023
    Texas
    I?m having the same issue on my 2020 Duramax, I have the MPVI 2+ and the GM E41 unlock kit. Did you figure out why yours was not reading ?
    Hey guys! I am having this same issue. Has anyone come up with the solution?
    Apr 2021
    38
    Resync your device and check to make sure it has not been disabled.
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    476
    For everyone having issues.. i have seen multiple people NOT put the red and white wire in the correct location on the ECM fuse.. Or using the wrong fuse all together. 2017-19 are a different fuse than the 20+
    Also make sure the batteries are good and charged
    Internet needs to be GOOD
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Nov 2023
    columbiana ohio
    25
    im having issue reading l5p dmax its a 2018 says failed to retrieve flash data i beleive unlocker is installed correctly resynced and retried many times no go . good hotspot connection via my phone. latest beta software. im stumped. whats going on????
