Throwing something else in here I used for info..
https://forum.hptuners.com/showthrea...se-width-table
The off-time seems like a characterization value. I've tried zeroing before, made everywhere richer, but I saw no need.
The way I was interpreting the M/U pulse in HPT, example:
- Factory LSA, M/U Pulse Minimum = 1.28125ms. Say this minimum pulse value delivers 1 g/s of fuel
- Install injectors flowing twice as much as stock
- Now this minimum pulse of 1.28125ms, is delivering 2 g/s of fuel
Using the M/U Pulse Minimum HPT description, anything under 1.28125ms will be ignored. So you've gone from ignoring anything under 1 g/s of fuel (stock injectors), to ignoring anything under 2 g/s of fuel (2x flow injectors). Now the M/U pulse is less effective and has less range than when stock.
So if you wanted to keep the stock characteristics of the M/U pulse, you'd need to lower the Minimum Pulse value by the value of injector size increase.
Using rough example above:
- Injector size has doubled
- Cut the M/U Pulse Minimum in half = 0.640625ms
Now any pulse less than 0.640625ms will be ignored, so it's back to a 1 g/s of fuel minimum, same range as stock.
I think it's always going to be an approximation when using different injectors. Would need to know the flow rate of old vs. new injectors at your fuel pressure, and then there's all the changed characterization of the new injectors (offsets etc.), and fuel systems with varying pressures (stock LSA/LS9, 1:1 regulated).
Anyway, when M/U Pulse Minimum is set lower, AFR goes richer. So maybe just set to a value that makes sense, dial fuel in off that value, and move on.
